gpelite »
https://forums.nicoclub.com/gpelite-u31517.html
Fri Jan 19, 2007 6:48 pm
The most important thing with a swap is making sure the breaking in of the new engine is smooth and that everything is sealed and well lubricated. Some engines sit around more than others. If you do not have a history of service on the engine, which most don't come with, make sure you due things similar to the mileage on the engine example:60k tune up. Your father has a point in checking the transmission and clutch while you are tearing the car apart basically. Now may be the time to upgrade several other components like turbos, boost controller system, Innercoolers like SMIC to FMIC, plan out what you can afford.
Don't drive the car around now, I mean a knock is not going to get better but it can get worse as evildky said. You will only be adding miles and pushing a dead engine. If you want to resell old parts like injectors, turbos (assuming your new engine comes with them), etc you might want to stop driving it. If the rod tears out parts of the block where is it gonna exit? chunks may fly through your exhaust manifold and K.O. a turbo or mess it up at least and ppl pay decent cash for used TT turbos in nice shape. If you need the turbos or other parts again... then yea just stop driving it
