learnautobodyandpaint wrote:
What you need to do is make sure you sand your whole car down with at lest a 400 grit paper.
320
You will want to use a base coat clear coat paint as this is the most modern and easy to use paint.
single stage is fine for those on a bugget
Apply your 2 coats of base coat.
depends on paint
learnautobodyandpaint wrote:Mixtures will depend on each paint brand.
while this is somewhat true
urethane clear usually mixes 4:1
