AZhitman wrote:
No, he has plenty (WAY plenty) tire on the car.
You'll have to experiment with rear bar size. Start with something bigger than what you have, keeping the rubber bushings. If it's not enough, switch to poly bushings. If that's not enough, shorten the endlinks somewhat. If that's not enough, go bigger on the rear bar.
Small steps.
I think he was talking about evening it out front to rear... and I would agree, if you're pushing through corners you need to even out the tire size... what tires are you running?
I assume you meant you had 8.5/9.5 rims sizes... for the $ you'd spend on misc equip you could buy some used tires for the front that match the rear...
Sell the whole set of tires and buy a "square" tire size F/R that would work on both rim sizes (like a 235 or 245)...
Get a tire that has more grip (softer compound) for the front...
Sell your 2 way and buy a 1.5/1way or helical lsd as 2 ways can signif exacerbate understeer... to help explain:
http://www.limited-slip.com/ac....html...granted you say this is on tip-in, but are you saying this is occuring in a transition from off to on throttle... or is it happening only while on throttle and not off throttle/transition (just to be sure)?
I'm still running the stock Hicas sways and VLSD with Kei Office coils and strongly feel the car doesn't need more swaybar... granted I have a cage (probably out of your budget if you don't want to buy new wheels, but I STRONGLY recommend one in these old cars)... tire stag was 235/245 on a 9/9.5 17" wheel setup... moving to 245/265 9.5/10.5 18" wheel setup, but I don't have understeer issues to deal with...
Looks like you have almost the same car as I do as a base (mine's a 92 Hicas)... is yours a hatch? You'll spend A LOT less money overall if you take care of the car's basics to dial in the handling characteristics you want... some people like a bias towards understeer... others like a slight bias towards oversteer (like me)... I use to fight this with my old T2 team with our 350Z... luckily you're not sharing the car, that makes the setup very difficult
Have you tried left foot braking on corner exit? Be careful... you're on a autox course, but some of those are fast and a car can really come around if you're not careful... but this is a good way to get the car to rotate without modification if it's only in certain corners that you're having the understeer problem...
I think the #1 question to ask is this... what are your alignment and damp settings? Looks like you have a few parts that allow some adjustment... what are you running for toe especially? ...this could be killing your handling... I know the stag is making the problem worse, but alignment might be going well beyond that problem... and that's a very inexp fix... oh, and what settings are you running on your LSD (assuming it's adj)?
What class are you running in... this will dictate what mods you can run, but I'd strongly suggest a cage... esp if you have a hatch... night and day difference... you can see mine if you look at the pics I have in my signature
Hope this helps and I'd be happy to help more if you can give us some more information... good luck and enjoy the car!
Here is a link to help with alignment/tire pressure (saw your camber post but trying to keep this all in one place):
http://www.elephantracing.com/...p.htm
Re-reading the above link reminded me... spring rates... what spring rates do you have now? This could easily adj your handling issues and is might be less costly than new swaybars... I found SPL provides a ton of spring options for you:
http://www.splparts.com/main4/...t.htm
I wouldn't buy sways until it's really something you NEED... like my DD... my daily is a 05 Audi S4 Avant 6MT... almost 4k lbs... even with KW V3 coilovers it needs some help in the "roll" department... but S13's can dial most issues out with coilovers and body stiffening, esp since you're starting with Hicas bars...
Oh, and with camber... don't forget caster is a way to chang dynamic camber (camber while turning) and not change your static neg camber if you're having tire heating issues... it's all a big balance you'll have to play with...
Dampers is also something to consider... here is the best article I could find to help tune these as well:
http://www.ozebiz.com.au/racet....html
I said it before... but it is very important to match a damper to a spring rate... if you drastically change spring rates you might consider having your dampers revalved...
...again hope this helps and good luck this season!
Modified by rbsileighty at 7:42 PM 3/29/2010
