how much oil to use?
mkory
Car: Mazdaspeed Miata
I changed my oil for the first time on my 240 a while back. Now its that time again, but I was wondering... How much oil do you put in your cars? When I changed mine last I replaced the filter (like always) and started with 4 quarts, checked it, and it was OVER. How much should I put in?
AmIdYfReAk
Car: 1990 240SX Coupe
3.7L if i remember correctly.
sanioll
Car: Nissan 240SX SE
Toyota Camry
3.75 quarts for sure will fill it.
but some say 4 quarts with filter, i mean .25 doesnt really matter, but 3.75 i saw in my service manual with the filter included.
make sure to pure some oil into filter(fill half) before you install it and run your oily finger onto the circular rubber once.
pmkls2
Car: 1990 240SX Fastback
the correct amount with filter is 3.75, but I always put 4 in anyways. that little doesnt make a huge difference but some people care........
DAEDALUS
Car: 1990 Infiniti Q45
sanioll wrote:3.75 quarts for sure will fill it.
Sure .25 qts probably won't matter too much, but what year manual are you looking at?
pmkls2
Im just speaking from my experience in the quick lube shops before I became a professional mechanic and from experience with my own car which reads full at about 3.75 quarts.............
mkory
Thanks guys. And I think I figured out why I was so over. Lets just say I jacked up my car on the passenger side, and didn't level it out and let all the oil drain out of the pan (location of drain plug). I figure there was some left in the pan when I added the 4 quarts. What's the harm in running with more oil anyways?
crzycav86
Car: 93 Nissan 240SX KAT
mkory wrote: What's the harm in running with more oil anyways?
Something about the oil getting really frothy and not lubricating well because the crank starts whipping it.
sanioll
Toyota Camry
oh my god, i feel like a fukng idiot. all these years i've been using 3.75 instead of 4 quarts.
heard it from pep boys, that it is 3.75, so didn't bother to check the manual properly. its w/out the filter change. heh.
i can't believe my 240 was hungry for oil all these years.
SO ITS 4 QUARTS, HERES THE PROOF ONCE AGAIN.
mkory
Woah, you're actualy supposed to replace that washer at the drain plug?
sanioll
Toyota Camry
Heillll nooooo! unless its really in a bad condition, aka leaking.
i think 240's got copper on there, so no need to replace it.
DAEDALUS
Most people don't and don't have problems. But the washers are crush washers to ensure a good seal. They can only crush 1x really. After that they're essenitially just flat washers.
Bronze MFP
Car: 1987 Nissan 300ZX w/digital dash radness
i replace my crush washer every time. they give em to me free with an oil filter at the nissan dealership.
sanioll
Toyota Camry
DAEDALUS,
you seem to know about oil stuff alot..
is pureone purelator (latest one for $6) better than OEM nissan oil filter?
DAEDALUS
I don't know which one is better, but they're both good filters. There are independent studies out there if you google for them, but they don't usually test factory filters, just aftermarket ones. I've read the most important thing is to change the oil/filter every 3 months and use a quality oil. Fred (palmerwmd) is the oil expert here.
