WerdEstoMax wrote:your gonna have a fun time taking that oil filter off aftewards, you shouldnt tighten it more then hand tight
Depends on <how> excessive.babowc wrote:its not too hard to take it off, with some man power. ya wuss :P
haha, just messing with you.but what are the consequences if i dont drain the oil and just drive at it's already excessive state..?
Same here... Also never tighten it more then hand tight... if you ever strip those threads your screewed... and it makes it to hard to get off!lrb_2000 wrote:i usually just put the filter on.. put about 3 1/2 quarts... start the car for a second to get the filter full.. then check the level.. if it needs more, I put more..
The damn thing is hard to get off when it's hand tight. On a slightly related note, it's kind of cool that those K&N filter have the nut on the end so you can just take it off with a regular wrench.Kenrik wrote:Same here... Also never tighten it more then hand tight... if you ever strip those threads your screewed... and it makes it to hard to get off!
yea even when i handtightened my k&n filter i had to use the wrench end to get em off.. so its defiantely very easy to overtighten those thingsBadMojo wrote:
wow, just wow.Dookie wrote:At least you didnt do what this guy I know of did. He filled his oil all the way up to the valve cover, haha
thats great.. Back at Vo-tech, vehicle maintance class in high school, this one guy i knew filled the entire windshield washer fluid tank up with oil while doing an oil change. " I DIDN"T KNOW WHERE ELSE TO PUT IT" ha ha ..Dookie wrote:At least you didnt do what this guy I know of did. He filled his oil all the way up to the valve cover, haha
