How much oil in RB20 transmission?
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
Since I'm really lazy at this point and I have limited room to work on the car. How many bottles do you need? 2.5? 3 bottles?
DCIracer
3 quarts is sufficient. 4 quarts will sometimes cause overflow...and the last thing you need is transmission fluid on the underside of your car...can cause fires.
Carl H
2.75 litersanymore and its overfilled.this will cause slow/hard shifts.
wga240
Car: 90 Hatch w/ RB20
The transmission should just be filled until the oil flows out of the fill hole, right?
Andrew85cm
Car: 89 240sx with RB20det
Like Carl said the transmission takes just shy of 3 bottles. That bolt to fill it is a b**** to get off considering I have the motor already installed.~ANDREW~
