The cap will not reduce the overall load. It will smooth out the power delivery by reducing the AC component (spikes). You will see the light dimming disappear but the fact is, it does nothing to reduce the load.Rex wrote:In almost any car it's easy to overwork the battery or altenator, the Q would be no exception to this.
First, what battery are you running, I'd suggest you have at least a new-ish Redtop Optima.
Second, if you haven't, at least consider a second battery or a capacitor. The "cap" is designed specifically for what your describing - momentary burst of "12 volt power needs".
Lastly, qsiguy may be able to offer some real advoce, as I'm pretty sure he's in the 12v game.
Could be an indicator/beginnings of a weak alternator (Jesda)... which creates a vicious cycle when a ramped up stereo system is added.CrimsonQ wrote:You guys using cheap chinese amps or what?
Ive never had an issue over 3 years with that. Seems kinda weird to me?
I dont blast mine real loud or for long periods, but thats all i can see that might be different.
Ive always ran red tops though...
Jesda, you are way too young for Duran Duran!I don't think you were born when I was listening to that!Jesda wrote:While listening to Duran Duran,
I replaced my Mercedes alternator that was a 65 amp with an AMG 150 amp unit from a CL55 without any problems. It has been running well for over a year now. I also replaced the battery with a Optima red top at the same time and used some 0 gauge wiring. All that while still using the factory Becker cassette deck .friedrice2841 wrote:
A third option is to get a larger or re-wound alternator. I would caution anyone from doing this. By increasing the alt size (and output) you can potentially damage other electrical components in your car.
Most cars are designed efficiently. The alternator puts out enough power to make everything in the car work. There usually isn't alot of headroom for aftermarket stereos, lights, playstations, etc. Q's are no different.
Ah Jesda..... why not share some funky town with the boys....let the real inner you be let out for those who don't know how attached you are to your 70s and 80s music .Jesda wrote:While listening to Duran Duran....
Good to know. I'll have to look into a dry cell since I'm always entertaining guestsfriedrice2841 wrote:Using a cap is not the answer. I have a 2 Farad cap. I am running (1) 400 Watt RMS Sub Amp and (1) 75x4 watt RMS amp to run my mid and highs.
My lights still dim when there is heavy bass burps.
A dry cell battery will take care of the problem. I believe Kinetik is one of the best dry cells for this application. The beauty of dry cells is that it doesn't matter how you mount the battery. It is guaranteed not to leak. You also might think about using a battery isolator. It is just a relay that only charges the 2nd battery when it needs it, so it doesn't continuously keep re-charging from the alternator.
Man, I recently downloaded the extended version of Funkytown from iTunes. Driving to the post office has never been more fun.lino wrote:
No more ace of base?Jesda wrote:Thanks all for the help!
And DD is still putting out albums.
Chiming in a little late but I agree with Skibane. Nothing to worry about. People spend lots of money on caps, extra batteries, bigger wire, etc. but it's not always needed unless you really have a lot of current draw from your system, it just takes a second for your system to up the power for the demand. You might put an excessive load on the alternator and/or battery if you were to try and sustain a low bass frequency for an extended period of time but normal music rarely has tones like that. You would need to connect a frequency generator or put in a test CD that has various frequecies to test the system and find rattles.Skibane wrote:.....So, momentary dips in battery voltage aren't necessarily anything to worry about. As long as the voltage recovers quickly after each "thump" - and recovers to a healthy 13.8+ volts - the alternator isn't being taxed beyond its limits.
