EZcheese15 »
https://forums.nicoclub.com/ezcheese15-u102.html
Mon May 30, 2005 2:46 pm
I'm doing a survey....please answer the following:
How much would you pay (assuming you had the money and were in the market) for the following?
A rebuilt to new SR20DET, harness, timing chain, transmission, stock specs, with ECU and harness
A mildly built SR20DET, 86.5mm bore, forged pistons, bearings, rods, balanced, cams, springs, retainers, ARP studs, metal head gasket, etc
A completely built SR20DET, overbored, pistons, rods, polished crank, manifolds, turbo, pre-tuned fuel management, etc, able to hold 500+ reliably to the ground--a direct drop in, no tuning necessary.
