NateDogg »
https://forums.nicoclub.com/natedogg-u710.html
Tue Jan 31, 2006 9:50 am
1/4 mi improvement is not just from the hp increase, but also from the significant weight savings, approximately 40lbs. I would say at least .2 sec in the 1/4 will be gained.
S&S is currently the best designed header for the KA. Longer primary runners give a larger torque curve and the 4-1 design allows the engine to breathe higher up top. However, it has clearance issues, can't remember if its with the steering or ground clearance, or maybe both.
