How much Hp should i be at
TonyStarks29
Car: 1994 Nissan 240SX Convertible w/ SR20DET
ive had my set up for a few months and ive never taken my S13 to dyno i dont have the $ to go this summmer (to many other things need to be worked on my house) but im wondering can any one give me a guess of where i sould be at with the list of mods i put
SR20 (black top)Gt2871R740 CC injectorsAir fuel controlerNistune board + Tune3 inch exhaust (ebay brand)
(Edit) My cams are Stock i have a Z32 Mafand an aftermarket FMIC (forgot name of brand)225 fuel pump
(i boost at 20-22 Psi daily what should i be at?)
Modified by TonyStarks29 at 5:12 AM 7/1/2009
240life
Car: 1993 Nissan 240SX S13 Coupe SR20DET blacktop
whats your maf, intercooler set-up, are you running stock cams?
supreamS14
Car: 96 240sx S13-blacktop Sr20deT
If you have a 255 fuel pump and fmic I think you might be able to hit as much as 400whp with the stock cams.
TonyStarks29
anyone know how much power the Sr can fully handle before a problem with stock cams
supreamS14
The most I have seen someone make with stock cams is 360 or 380whp so far.
DrifterProdigy85
Car: 1989 Nissan 240sx (Zenki Onevia)
400whp has been done on stock cams but it was with a GT30R .63. Using a 2871R only nets right around 330-350whp.
240life
I run a built bottom end w/ gt 2871r .64 A/R stock cams ( every freaking bolt on too) @ 21psi I am deffinetally making over 350 whp probably close to 380 and the engine still pulls harder then my rev limiter will allow I want to dyno the car to get deffinate #'s, but this car is almost to fast for the street. I am willing to bet the 330 is being conservative, but I also believe to make over 380 and break 400 you will need cams with our turbo
SR20_S14
Car: 1996 Nissan 240sx SE
with the potato you should be around 350 thats where a friend of mine is at with around the same set up
V8slayr
Car: 97 240sx
A 2871R is not the potato my friend. The disco potato is the GT2860RS
DrifterProdigy85
240life wrote:I run a built bottom end w/ gt 2871r .64 A/R stock cams ( every freaking bolt on too) @ 21psi I am deffinetally making over 350 whp probably close to 380 and the engine still pulls harder then my rev limiter will allow I want to dyno the car to get deffinate #'s, but this car is almost to fast for the street. I am willing to bet the 330 is being conservative, but I also believe to make over 380 and break 400 you will need cams with our turbo
I had the same setup as you and did 350whp 350tq @ 20psi years ago. The tq peaked very high early and constantly fell as the rpm's increased. It feels fast but its just the feel of fast spool and tq. The cams are a huge bottle neck in the SR engine. They pretty much cant flow for s*** past 5500rpm. To confirm the horsepower it was running consistent 115mph trap speeds. Once i upgraded the cams and manifold and got it tuned, it was doing 122mph @ 21psi.
240life
Those are still respectable #s. I was estimateing the cars potential, as I have not had any dyno time....unfortunately right now I have 0whp, my car lost oil pressure and i found a trail of oil leading to a puddle under my car. I think my upper oil pan cracked or lost it's seal
kentuckyslider
Car: 02 IS300 manual/03 G35 sedan auto
My 2871R with stock cams and intake did the exact same at 20-21psi. I also trapped 115-116 and made 345whp/350tq with that setup. I am definatly not a fan of the intake mani on the 2871r. I would do HKS 264 cams and leave the stock intake. You will make plenty of power and still have 350+ wh/tq. You lose more tq than you gain whp with the intake. It is a much more well rounded car with the OEM intake and mild cams with the GT2871R IMHO. It should do 375-380whp and over 350tq and that is bad a** in a 2600lb car.
DrifterProdigy85
Yeah its not worth going to a Short Runner Intake unless seeking power over 7500rpm which a 2871R wont make power at those revs anyways. Ive often thought about taking my stock manifold and making a large plenum for it and use a Q45 TB. I would think it would make alot of tq from the long runners and still have good flow for high rpm with a larger plenum and throttle body to match.
overdosedave
i had the same setup but didnt get to enjoy it because i kept the boost at 7 pounds..
Koshin
Car: JP'd out Y32 Nissan Gloria GTU
750 hp '87 Buick Grand National
'63 Chevy Impala SS 327/4 speed
overdosedave wrote:i had the same setup but didnt get to enjoy it because i kept the boost at 7 pounds..
y?
dc1984
Car: 93 240sx/98 180sx blacktop sr20det :RIP/ 93 jeep grand cherokee
why do u have an air fuel controller and a nistuned ecu at the same time? kinda pointless.sell the air fuel controller, get the car dynoed and still have a few extra bucks left over.
