HOW MUCH HP OUT OF KA24E?IS IT WORTH THE TIME?
splintercell
Car: 1989 Nissan 240sx HB CA18DET
1991 Nissan Silvia Q's SR20DE ITB's
I HAVE 312,000M ON MY ENGINE,NO KNOCKS,NO OIL LEAKS,PREVIOUS OWNER TOOK WELL CARE OF,SHOULD I REBUILD THE BLOCK I HAVE WITH BETTER PARTS? HOW MUCH HP GAINS OUT OF A N/A ENGINE.IM ALSO THINKING OF A CA18DET,BECAUSE ITS HALF THE PRICE OF AN SR20.IM WORKING ON A TIGHT BUDGET AROUND A NON WORKING WIFE AND 2 KIDS
240DRFT
i wouldnt go with the ka-e if i were u...thats a lot of miles and its only a single cam
splintercell
YEAH ILL SCRAP THAT IDEA,I SAW A CA18DET ON EBAY FOR 1200.I MIGHT HAVE TO CHECK ON THAT.I DID NOT REALIZE THOSE ENGINES WERE THAT CHEAP
TheOne
Car: 93 240sx FB
i'd keep the ka, build to stock specs and put a turbo on it.....that way you'll have more torque to play with.(or you can always get another low mile ka for less than $400)
SlowBack
Car: 240sx
TheOne™ wrote:i'd keep the ka, build to stock specs and put a turbo on it.....that way you'll have more torque to play with.(or you can always get another low mile ka for less than $400)
I'd go with a low mileage KA24DE and turbo it. Those single cams are kick *** if you take care of them and don't let them overheat. What's the performance like on a single cam KA with over 300K miles?
240marcuSX
Car: E34 525i
E46 M3
if i had two kids and a wife to support the last thing i would be worried about is throwing money into a car.
the E itself is a fine motor to do all kinds of ugrades to. but thats alot of miles for any motor, Id say it would probably need a full rebuild.
Thee 240sx Owner
Car: Canadian 89 240 with LSD/stock no ac/ and 4 motor swaps
i like how people say alot of miles but when i got a hold of the nismo catalog from nissan when i was there.. 2 pages of it is aimed at the SOHC because of its simplicity and its longevity... i would say maybe a qtr page was aimed towards the DOHC with just minor stuff like pistons, rods, cam gear and rod bearings... the SOHC they had listed every single high performance part for that motor... they praised it more then the SR
justmerging
Car: 07 Versa SL w/CVT Cuz I'm lazy
The sohc can be a beast with the right budget. it's still the preferred motor for scca racing(see sig). If you are on a tight budget though you may want to go with the ca18det. N/A high comp KA is a blast to drive though. However it's not very streetable.
