How much hp could I expect from this combo?
Beau
Stock displacement SRS15 turbo550cc injectors9:1 compression pistonsGreddy intake manifold (mildly ported and port matched to the head)HKS 264 Step 1 camsMildly ported headMildly ported and port matched stock exhaust manifoldGreddy 02 housing3" exhaust w/ no catGreddy VSPL intercoolerAll necesary supporting mods
Assume it is tuned to perfection and if I didn't mention a part, it's probably stock. My goal with this engine is to be as powerful and responsive as possible.
How much boost could I run with the slightly higher compression pistons? I'm considering the 9:1 pistons to get a little more power and make the turbo spool faster.
