how much for an sr20 swap
NoTcHbAcK240sx
I just wanna know basically how much a sr20det swap would cost for everything i would need to run.. i have 7,000 for my car and for swap and upgrades. i wanna know if it would be enough.. thanks man!!!!!!!!!
Shift_Smoke
1991S13
Car: '91 240sx Coupe, '00 QX4 4x4, '02 Sentra Spec V
Click the search button in the upper right corner of the window and look it up, I bet you find a lot of answers...
Also check out some of the links all over the board, that will help you out a lot too.
The price really depends on what all you are looking to buy. Do you want a front clip or just the engine? I've seen them priced anywhere from around $1,000 for just an sr20 up to $6 or $7,000 for one with upgrades already installed. Also do you plan on doing this yourself or are you going to need a shop to do it?
GEO
Car: 95 240sx KA-T
$7,000 MIGHT get you buy... theres alot of hidden costs. Believe me, you will end up spending like $10K to get evrything running like you want it.
Nismo_Freak
Car: 89 Nissan 240SX
GEO wrote:$7,000 MIGHT get you buy... theres alot of hidden costs. Believe me, you will end up spending like $10K to get evrything running like you want it.
~5k will get you an off the shelf BPU setup.
NoTcHbAcK240sx
I want a front clip but which ever is cheaper for ever how much i get is what i want.. 7 grand i hope its enough.. do you guys think i should just buy a already swaped 240 and save money? or do you guys think the engine will most likely be raped?
o_alcha3
already swaped is cool, it may or may not be raped but when you see the car going through the transitions and if you work on it yourself you end up liking it and appreciating it alot more. i would personally not buy it swapped.
Juujai
7k is plenty many shops around here are 3k for labor+clip and if u want a fmic, fuel pump, a/c, downpipe, all that junk its another k or 2. thats redtop though blacktop is a little more expensive not much though. SR frontclips a couple years ago were like 1200 for reds now it can be upto like 2500-3k thats sick. its like a luxury to have an sr now back then we did it cuz it was cheap vs KA lol. a lot of ka parts are so expensive even gay things like power steering pumps cost so much.
mmatl16
Car: 240sx rb20 swap
7k is plenty to get started. i know a place that will get an s13 blacktop, install it and itll be 3100 out the door. that leaves you 4 grand to do whatever
NoTcHbAcK240sx
is that with fiel pump and a/c downpipe and everything i need? if so can i get tha number
nipo
I'm in Philadelphia, i would love to know where this shop is. Please post website or phone number or something, thanks
spanishricer
Car: '95 240SX & '03 M45
NoTcHbAcK240sx wrote:I just wanna know basically how much a sr20det swap would cost for everything i would need to run.. i have 7,000 for my car and for swap and upgrades.
So does this mean you have $7k to spend on a car AND the swap? If so, you're definately going to have to get an S13 for a couple thousand dollars then spend the remaining $5k on the swap and fixing all the lil' things that are bound to be wrong with a 12+ year old car...
MakotoS13
or you could put a real motor in the car...
TheLocust
I recognize that name from somewhere^^^Zilvia? But yeah if you wanna come pick my car up I'll sell it to you for 6k. Its a 90 S13, flat black..widebody, red top SR20, BPU+, wheels, coilovers, upgraded brakes etc, electronics etc.. Car is located in Cincinnati Ohio.
240sx2soon
Car: Soon to be 96 240SX SE
Let me see, $7000? I would say IAP turbo kit, suspension and brake upgrade. I have a feeling you'd be happier with that than spending $7000 on an SR and still needing to put in suspension and brakes on top of it, you should get the same whp if not more and you'll actually be able to put it to the ground and stop it!!! I love the idea and the practice of swapping SR motors but after comparing the price to a KA24DE turbo'd I just can't justify it anymore.
Juujai
it's not so simple as just buying a turbo kit and slapping it on.. doing anything to a car costs money regardless of how you do it.
fuel pump, bigger injectors (detonate w/o it)bigger radiator, e fanfmic, piping, (...)motor/transmission mounts (stocks are done)z mafs, plug, adaptor, harness (250hp +)
you're looking at probably ~2grand extra there or less depending on how ghetto it's done...
add all that junk up + your turbo kit +other crap i mightve forgotten like an ecu tune etc. also i wouldn't trust a car i haven't driven all my life... i'd rebuild or atleast tear down the motor for inspection thats $ too.
all that money and the motor still feels sluggish, revs like junk, responds like... do what you want not my money.
what brake upgrade...? z32 fronts? it won't help much unless you track. it's basically just for extra heat dissipation/tolerance. unless you track/race and the stocks are warping/fading theres no need to upgrade... braking distance won't decrease much either.
not trying to bash too much but problems/situations will arise and you gotta be down to put money in it. we aren't dealing with brand new cars so we can't just slap on a turbo kit and call it a day.
wickedpelf
Car: 1991 240sx with super hicas
YUP!!!! there 2-3k worth of little sh1t u have to buy like my engine came with a bad ECU, no wireing, no ignitor chip...etc etc
NoTcHbAcK240sx
the revivial of my post that was started almost half a year ago.. nice lol.. i think im going to go with the ka-t.. from the researching ive done ill be getting more whp and be spending less money.. still not sure of what im going to do..
c-rad
Car: 1991 Nissan 240SX w/CA18DET
For $7k? Dude, you should buy this guys 240 on a local board here in FL.... He wants $5500 for it. http://www.floridadrift.com/fo...light=
Ni2s4s0aSnX
Car: Nissan 240sx 2.4L 12Valve
Depends on whether you're doing it yourself or not. If your doing it yourself it wont cost you more than $3500. And with the rest of that money you can get an exhaust, intake, camsahfts, ecu, turbo upgrade for the SR, 7 grand is enough to do pretty much anything with the 240sx.
Teerawood
save your $$ for college.
GrilledCheese33
Car: 2008 Nissan Xterra
1972 Yamaha R5
2017 Sea Doo Spark Trixx
Teerawood wrote:save your $$ for college.
Good idea, b/c hes only 16
NoTcHbAcK240sx
not going to college.. my uncle got me into the plumbers union of new jersey so i will be making good money there and right away.. not built for college... so soon enough i will have my s15!! lol <--- i wish... plumbers union all tha way babyyy
Teerawood
and
NoTcHbAcK240sx wrote:not going to college.. my uncle got me into the plumbers union of new jersey so i will be making good money there and right away.. not built for college... so soon enough i will have my s15!! lol <--- i wish... plumbers union all tha way babyyy
and thats when your life starts to go down hill.. seriously.. college is the best things that has happend to me.. save your $ for college. you want to work a plumbing job for the rest of your life? haha oook
do the mario!
Morph
Car: 91 Sr Powered Coupe
240sx2soon wrote:I love the idea and the practice of swapping SR motors but after comparing the price to a KA24DE turbo'd I just can't justify it anymore.
Yes lets slap a 2-3k turbo kit on an engine that has 100k+ and wait and see what breaks 1st.
