elwesso »
https://forums.nicoclub.com/elwesso-u5248.html
Sat Oct 25, 2003 3:59 pm
Back to your origional question, if you did EVERYTHING you need to do for the 60k service (oil/filter, transmission fluid/filter, PS fluid, Brake fluid, plugs, inspect brakes, rear diff fluid) you would be looking at quite a bit..... $120 for the flush, $50 for the pan drop and filter change, 20 for oil change, $30 for a PS fluid flush, $600 for plugs, $30 for the rear diff and however much for the brakes, youll be looking over $1000....
Note that all this stuff can be done (as I have done everything except brake fluid, but its fine since I have recently got new brakes) for less than $200..... $50 for a set of plugs, cost of fluids for the rest of the stuff, and 100 for a transmission flush, DIY the pan drop and filter change......
