First sr i see with more tq then hp. Also, what other mods does your friend have, what turbo, tune?CoupedUp wrote:BTW, SRs can make torque. My friends S14 SR w/ S15 Injectors and Z32 MAF with AFC NEO made 284WHP and 294WTQ.
Thanks man... clears up the fogOnizuka wrote:^It doesn't work that way.
To the opening poster, You could be making less than 200hp without tuning. I had a similar setup to you and before tuning (and at 7psi) I was only putting down like 170hp at the wheels. After tuning I maxed out the stock MAFS at about 255whp and had the s15 turbo at only 10psi. I learned from that experience that your parts list means absolutely nothing without a good tune. Theres a good chance someone with a completely stock s14 sr is putting down more power than you.
Like me, ah hahahaOnizuka wrote:^It doesn't work that way.
