how much does rust repair cost???
WI_S14_Goldie
Car: 1995 Nissan 240sx SE, 91 240 fastback LE, 1997 kouki S14, DD = 93 Nissan Maxima
I've got a beater that needs rust repair on the coner panels...how much do the repairs usually cost? Any help would be great. Thanks.
Hijacker
Car: '92 240sx Convertible
'94 F-150
It depends on the extent of the damage to be honest and what the locals charge to do fix it. Take it a good body shop and have them give you an estimate.
89ess13
Definitely depends on how bad the rust is. If its surface rust it can be sanded and painted fairly inexpensively. Flaking metal and rot will need to be cut out and a new piece bent and welded in place. This is where things get expensive. Only the shop that does the work will have an accurate quote for you.
