how much does it cost to build a DRIFT car?
myslowSilvia
how much does it cost to build a proper drift car this? car sounds so damnn good!!
PapaSmurf2k3
Site Admin
'bout 20-30 grand.
MeanGreenS13
Car: 2011 Chevrolet Silverado 2500HD
Depends if you want a nice one or not...
You could just get a cheap beat up S13, drop in a junk yard LS 5.3 and a t56 with some BC coilovers along with other odds and ends you need and you can do it around $5000 probably.
If you want to do it right, 20-30k is about right as mentioned above...
Dorito_Club7
Car: 1995 Forest Green S14. Bone Stock
yeah it can be costly, but you can always check out budget builds. definitely want to start on a good set of coilovers and make sure that the surrounding suspension components are up to par. Also look into getting a nice sway bar.
https://apparacing.com/shop/suspension/ ... 0-311-b18/
myslowSilvia
PapaSmurf2k3 wrote:
Thu Dec 13, 2018 11:08 am
'bout 20-30 grand.
no way it shouldnt cost that much. the guy in the video said he bought it for 3 grand. im so confused lol
myslowSilvia
MeanGreenS13 wrote:
Thu Dec 27, 2018 11:36 am
i think turbo sounds way better than ls engines. just listen to that sound at 1:53
Mitec
Car: RB20 S13 hatch
myslowSilvia wrote:
Fri Feb 22, 2019 8:43 am
'bout 20-30 grand.
The car may be cheap, but the amount of parts (and labor for what you can't/don't want to do yourself) adds up extremely quickly. Want a better suspension for more angle? Great, that'll be $500-1k front and $1.5k+ rear. Good coils another $2k. Don't forget bushings - poly are decent and cheap, but if you want top of the line, spherical can't be beat and those will run you $400 for just the rear knuckles. Bash bars for $200-300 each, or just get a tube front/rear for ~$1k when all is said and done. And then you have engine upgrades, safety ... it adds up quickly.
Sure, you can have a completely stock drift car and learn the basics, and maybe do fairly well, but at some point you'll want/need to upgrade. If you look at FD cars or the higher-level grassroots cars, they have $$$ of custom fab work into the suspension and body alone.
kornmanz
Car: 89 240sx Hatch SR Powa'd
I mean I'm totally balls deep at this point $20k+ (almost 10 years later) and it's not even done. :inout:
You could have just said, "Hey guys, check out my YT video."
After 16 years doing this, we've seen all the tricks. :rolleyes:
