Cjmartz2k »
https://forums.nicoclub.com/cjmartz2k-u65761.html
Thu Oct 04, 2007 3:20 am
OK, I don't know how many car sites I'm going to have to type this on, but here it goes again:
Back pressure of any kind is ALWAYS BAD. What people think they are talking about is exhaust gas velocity (EGV). Smaller piping for the same amount of flow means higher EGV which helps exhaust gas scavenging in the cylinder there by increasing hp (think putting your finger over the end of a hose). Having giant piping with a kink to "give you some back pressure" is about the worst combo of things you could do to you exhaust.
What you want is the smallest exhaust with the smoothest and least bends that won't restrict you at the top end of you RPM range.
That being said, all of the above is for N/A cars.
Now for Turbo cars:
All of the aforementioned EGV, exhaust gast scavenging, etc is negated by the fact that you have one big *** restriction in you exhaust; i.e. your turbo. It completely ****s up the flow of the exhaust, and adds some restriction to boot. On the plus side, the 5-10hp you loose because of that restriction adds from 50-1000hp depending on the size of your turbine.
So, in summary;
N/A (or supercharged)=you can go too big with the piping. Keep them smooth, straight and moderately sized.
Turbo= As least restricted (read big or smooth/straight) as you can after the turbo.
I hope most of that made sense, because I'm having to squint with one I to find the keys I'm so drunk right now.
