How much does an rb20det longblock weigh in at??? Will my engine stand support??
SuicidnS13
Car: SC300 2jz, 93 Vert (RB), AcuraTL
So I recieved my 2 rb20det engine swaps. The shipping weight for 2 complete rb20det swaps was 1652 lbs. How much does just the long block weight in at? I have a 750 lb. engine stand to put one of the long blocks on and want to make sure it can take the weight. Im pretty sure its not that heavy but the shipping weight on the reciept is confusing me.
thanks-
s13point5
Car: 89 240sx
it will hold. i had my RB25 on a 750 stand.
SuicidnS13
s13point5 wrote:it will hold. i had my RB25 on a 750 stand.
Did u use the oem transmission bolts to support the engine on the stand or go out and get longer ones?
mello88
Car: s13
I think I bought some new bolts from home depot, m10x1.5x75mm iirc.. My motorset didn't come with the trans bolts Motorstand supported it fine, but I know your concern! Be careful moving it around and you should be fine.
craz4240
Car: 1995 240sx w/rb20det
I'm assembling my second motor on a 750 stand as well,myself I used threaded rod and nuts to mount my block to the stand...:D
s13point5
Car: 89 240sx
i went to ace and got longer ones
SuicidnS13
The longest oem bolts only come out like a 1/2" past the brackets that hold the motor up. Is that enough?
lilskyline240
Car: 90 240sx w/ rb30det
i had my rb30 block on a 750 stand. Just got some Grade 8 longer bolts from Ace to hold it to the stand. was on there for like 7 months no problem
S14-NEO
Car: 1995 nissan 240sx RB25 NEO powered
most engine stands are designed to hold V-8..i doubt an inline 6 would much of an issue whatsoever.
lilskyline240
exactly my thinking. The guy i bought my engine stand from had a chevy 350 on there for like 4 years with no problem
JPsNissans
Car: 04' SE-R Spec V, 95' S14 240sx
I just have a Jegs no-name-brand stand, probably made in Korea somewhere by some 7 year olds.Been working great for about 4-5 months now.
I got a cheap metric engine stand bolt kit with it, put it up there with that and then noticed it was all grade 8 hardware.
I would use grade 10, I think 8 is a little weak for such a long bolt to hold that much. Im fairly sure some or all of my 4 bolts are bent slightly in the stand guides.
SuicidnS13
Home depot only had zinc coated metric bolts. Did that hold your motor fine?
gawdzilla
Car: none
go to advance auto and ask to go behind the counter. they have transmission bolts there (all black) not sure the grade but they are strong m10x1.5. I always get mine there and then use whatever washers lying around. i would not use the home depot zinc plated stuff.
SuicidnS13
We do not have an advanced Auto in Las Vegas. Is there anything similar to it?
