slownslurious »
https://forums.nicoclub.com/slownslurious-u29303.html
Mon Jun 12, 2006 11:42 am
if you can't find s14SE fronts in the junkyards, can't afford new ones, or don't want to have to drill anything, this is a cheap solution:http://hpautoworks.chainreacti...=1100
and since you can use the rears off a Z32 and they are all over you should be able to get a set of rear hubs for under $100 pretty easily from a junkyard. I got my S14SE spindles for $50 each for all 4 corners.
