How much did you guys spend on your rb swaps..
accordscantdrift
Im just curious how much it normally costs to swap in a rb25det or rb26dett engine into a s13, s14. What motor mount kid did you use?? did you use the stock smic or front mount? Also add any details you would like.
xjon
Car: 99XJ, 93 240coupe
$55-6K RB25det Mckinney mounts, fmic, check out the imagestation on my sig and it will show you what I bought with prices.
JonPowell
Car: Cars, Music, My family
I spent about $6000 or so including buying the car.
Mods were Blitz LM Series intake, Blitz Realize TT ECR33 Exhaust, and a Walbro fuel pump...other than that it was mostly stock.
NISMO_RB25
Car: 1992 240SX with RB25DET, 1987 RX-7 TII
I am currently around 13K including the car.
Here is what just the swap cost me
$3250 -RB25DET motorset (I requested the sidemount and got it included)$1150 - Mckinney mounts and Driveshaft$350- Wiring Mckinney$220- Flex-a-lite dual fans$200-hoses, fluids, misc$100- walbro fuel pump----------------------------$4120 total
That is using the stock sidemount, and doing all the work myself. That is also doing it without fixing anything, like the speedometer, and tach.
After the swap the car was overpowering the rear wheel, so I added a VLSD and axles ($350)
Hybrid FMIC with piping ($700)Tein Flex Coilovers ($1400)Tanabe Control arms ($1300)Poly bushing set ($100)Temp Sender ($20)S13 seats were crap so S15 seats ($750)Boost gauge ($40)Apexi N1 Dual Exhaust ($650)Shortening my Down pipe (free, I know a welder)I am probably still going to end up buying the one mckinney has for $220
The extra's to make the car handle the way it should with the new found power quickly adds up.
So my advice is that if you only have $4-5K to spend, you should probably keep saving up.
Not to start another war on wiring and mounts, but the time and hastle it saved me was well worth it. Read all the wiring and mount post and you will see what I mean.
I highly recommend the SR20 if you are on a budget.
Imissmyturbo
Car: Car's, Turbo's, sking
I am with Nismo on his comment about SR20 if on a budget. Or turbo the KA.I have spend close to 7K on swapPlus 1500 for car.Now I do have a larger turbo, FMIC, and Apex PFC.It all adds up.
s13rb25
Car: 89 240
Ive got about 5k in mine, but it still needs alot. the 5k includes car, motor, fuel pump, clutch, water temp and oil pressure gauges, dual fans, 3 inch o2 housing back exhaust. Still need suspension, brakes, seats, and more power. oh and my water pump seal is starting to leak alot so ive got to put a new pump in it also.
skillzilla
man, I know its an RB20, but I had my car running for only $2000, with tophat mounts
I paid quite a lot for my shell too, $700.
DETurbine
Car: Nissan S13 RB25
1800- RB25DET CLIP SETUP 280- ACT 2100 CLUTCH SETUP 500- APEX'I GTSPEC EXHUAST 150- 300ZX DRIVESHAFT 200- CUSTOM ONE PEICE DRIVESHAFT 80- PUSHER FAN 180- AUTOMETER CF GAUGES AND PROBES (WATER TEMP, OIL PRESSURE, BOOST) 200- EXTRA PARTS FOR SWAP (FLUIDS,BELTS, HARWARE, ETC...) 50- DOWN-PIPE (3INCH) 80- TEST-PIPE (3INCH) 150- R200 VLSD (Z32 300ZX NA) 100- J30 OUTPUT SHAFTS 100- WALBRO 255 FUEL PUMP 150- KOSEI K1'S (16X7.5) 320- (2) NITTO 555'S (245'S) 50- XS ENG. MANUAL BOOST CONTROLLER 20- GREDDY TURBO TIMER 200- KYB 4&8 WAY ADJUSTABLES 100- SPORTLINE SPRINGS--------------$4,710 -TOTAL
Fiendish
So far....$2500 for the RB25 clip (no BOV, IC, or MAF)$75 Q45 MAF$80 Blitz SS BOV and RB25 pipe$11 RB25 Factory Service Manual
I'm slowly sourcing my parts.
accordscantdrift
DETurbine wrote:1800- RB25DET CLIP SETUP 280- ACT 2100 CLUTCH SETUP 500- APEX'I GTSPEC EXHUAST 150- 300ZX DRIVESHAFT 200- CUSTOM ONE PEICE DRIVESHAFT 80- PUSHER FAN 180- AUTOMETER CF GAUGES AND PROBES (WATER TEMP, OIL PRESSURE, BOOST) 200- EXTRA PARTS FOR SWAP (FLUIDS,BELTS, HARWARE, ETC...) 50- DOWN-PIPE (3INCH) 80- TEST-PIPE (3INCH) 150- R200 VLSD (Z32 300ZX NA) 100- J30 OUTPUT SHAFTS 100- WALBRO 255 FUEL PUMP 150- KOSEI K1'S (16X7.5) 320- (2) NITTO 555'S (245'S) 50- XS ENG. MANUAL BOOST CONTROLLER 20- GREDDY TURBO TIMER 200- KYB 4&8 WAY ADJUSTABLES 100- SPORTLINE SPRINGS--------------$4,710 -TOTAL
Is that dealer cost? If I could get a clip for 1800 I'd do it right now. I would have to see it 1st before I'd buy it though.
Nameless EJ6
Car: What the **** do you think.
97 GTR motorset w/ RB25DET trans 4000$ shipped.
That's it so far. 240sx = 3200$
accordscantdrift
Nameless EJ6 wrote:97 GTR motorset w/ RB25DET trans 4000$ shipped.
Where did you find that motor?
Project240
Car cost me $1250. I spent about $5000 to get it on the road with the upgrades listed below.
Wykid 240
What's a good shop to buy a RB25 front clip from?
Jeramy
DETurbine
accordscantdrift wrote:Is that dealer cost? If I could get a clip for 1800 I'd do it right now. I would have to see it 1st before I'd buy it though.
No that is the hook-up cost, lower then destibutor cost. The guy was hurting for business and needed the money really bad, so I talked him into that deal. My clip came with everything and the motor was a SII and only had 17k on it.
Nameless EJ6
accordscantdrift wrote:Where did you find that motor?
Secret. ;)
red240sx sr20det
im looking at doing the rb26dett swap on my 1990 240 i already have a sr20 with mods but i dont like it and want the 6 twin turbo im looking for a the whole front clip of a r33 id love to get a vspec engine but i can keep dreaming of that never happening how much could i pick up the front clip of a gt-rand where also how much do you think i could sell the rb26dett trans for??
Project240
Yeah, those V-Spec GT-R engines can prove to be quite elusive, but always worth the money. Settle for the regular ol' GT-R motor if you want, I'd hold out for a V-Spec motor, or even a V-Spec II. Then you'd have some power.
.......wait, what??
:rolleyes Do some more research.
Nameless EJ6
lol.
