JerichoNike »
https://forums.nicoclub.com/jerichonike-u143795.html
Tue Sep 22, 2009 2:44 pm
Sr swap completed running excellent! boost a bit laggy but all in all job completed
THEN>
I was running intermitantly on 3 cylinders. Checked for spark-got itTiming-Just did itChecked for boost/vacuum leaksCompression was 150 across the board when installedMaf brand new and new SR harness.
????confused????WAS at LEAST
So just for the heck of it i take the fuel rail. Injector #4 is dry as a bone(scary)Its ohms to 11.6 so electrically its sound so i dropped it off today MI Midwest injections, to be tested, cleaned, and blueprinted. WILL get them BACK TOMORROW
Then i proceeded to check the plugs.Cylinder #4 white(scary) no chunks or oil
I have boosted the car maybe 5 times in 150miles(NO REALLY safer than sorry hopefully) I have been trying to learn the powerband in the Vacuum rpm's, as well as listening for other problems exhaust leaks, Brake noices
I am an ANAL BASTARD so I have not just Romped on it!
So How Much DETONATION can an SR20det handle?????
Can The motor detonate during vacuum?
Considering my cylinder # 4 was running with little to NO fuel how much damage could have been done?
Keep in mind it was an intermittent misfire/dead cylinder/Detonation symptom.
what do ya think?
BTW stock T25/ 7psi/ FMIC/ 3" exhaust/ sr maf/ hks bov/ ran like a champ 2/3rds of the time.
waiting for the clean injectors to come back 9$ per injector to do this BTW
I Now believe this to be absolutely necissary for all swaps i will do.
