How much current does the VH draw?
Discuss topics related to the VH41DE, VH45DE, VK45DE, and VK56DE engines.
CrazyTrance
Car: 1991 Nissan 240sx - vh45de
I'm curious as to how many Amps are drawn from the alternator from the engine alone. JUST the engine.
Anybody know?
Hmmmm.
You mean the injectors, sensors, ECU, gauges, etc?
The "engine" draws none. The electrical components do, however. Add them up (or ask Dennis, he probably knows).
CrazyTrance
AZhitman wrote:Hmmmm.
Yes thats what i meant, the components the engine needs to run.
Even in that case, you'll have to quantify that to decide which ones are actually "necessary".
Some are intermittent, for example. Some are variable in their draw.
Q45tech
Average vs Peak is a function of rpm just as the fuel pump varies significantly at idle/cruise vs WOT depending on rpm.
Injector duty cycle varies from 6% to 55%
Peak might be close to 30 amperes [including fuel pump/FPCU, ecu, tcu, injectors, coils, IAC O2 heaters, MAF, VVT solenoids
Remember alternator CAPACITY varies with rpm also it is almost never 110 amperes usually 40-50.
Careful the alternator pulley ratio is 2.5 [not 3] because the engine can spin 7300 rpm vs domestic V8...............for an altenator to survive 18,000 rpm is very special.
At idle the Q alternator probably has less amperes [1875 rpm vs 2250 rpm] than domestics due to pulley ratio.
CrazyTrance
Dangit. I knew you all were gonna ask these questions.
I guess what i need to know is at idle, how many amperes would it draw.
Fuel pump, Injectors, coil packs, cas, etc.
Not really extremely important. Something i'm just curious about.
Q45tech
For not really important waste of time consulting I charge $200 per hour how many hours do you want to pay for in advance?
Is that a warmed up idle or a just cranked idle........the diference is significant just as the rpms are different.
T45
Car: King Kong powered Z32
Lol.
You could check yourself if you have the time, desire and an ammeter. I would assume that the biggest consumer of current at idle would be the fuel pump. Then coils. Then injectors. Then the rest of the sensors. Just a guess. I would also estimate that the total current draw would be about 8-10 amps?
Q45tech
The fuel pump and fpcu varies depending on viscosity and temperature of gasoline and condition of fuel filter.
An ammeter will show average not true RMS current [the heating which blows a fuse]..................you need an oscilloscope and shunt to view the waveform of current to decide.
10 amperes is low as you will see.
Return to “VH45DE / VK45DE / VK56DE Forum”
