Any guesstimates?
Fred...
I think that the one Fred is looking at has the Exhaust/Intake/chip/boost controler= about 380-400 range?Rex wrote:Factory numbers were/are 300hp / 307lb-ft.
The following is an exerpt from Stillen Motorsport's upgrade chart: (notice that the upgrades are cumulative)
Stock 300ZX - 300 hp Stage 1: 320 hp @ 10psi - Performance Exhaust system Stage 2: 340 hp @ 10.5psi - Hi-Flow Intake Stage 3: 396 hp @ 13.5 psi - Computer Chip Stage 4: 405 hp @ 13.5 psi - Larger Intercoolers Stage 5: 418 hp @ 14.5 psi - Electronic Boost Control Stage 6: 450 hp @ 16.5 psi - Larger Turbos and Injectors Stage 7: 520 hp @ 16.5 psi - More tuning / dual intake Stage 8: 620 hp - Larger turbos and injectors Stage 9: Even more hp - Nitrous Oxide
