How much could an engine/transmission/ecu set net me?
Bohemiangod
Car: 1999 Chevy Camaro V6/5Spd and a 1990 Nissan 300ZX Twin Turbo!
If i were to do a TT swap. I would be ditching the motor, transmission, and ecu among some other things. Would those parts net me in terms of cash?
the motor has 100,000 miles on it and i have the gauge pod for it as it was swapped in maybe 3k miles ago. no modifications to the motor. well maintained. I swap oil (full synthetic) every 2000 miles. so far twice.
the transmission has a slight grind in 5th, but all gears work perfectly and i have no other problems.
The clutch and flywheel assembly could be sold i can surmise since the bell housing is different. The clutch has only 3k miles on it as well so i dont know how that would fit.
Anything else salvageable? and what would the going rates be?
EDIT: forgot to add that I have stainless steel headers and downpipes which i believe would be incompatible with a TT so those would go too.Are underdrive pulleys transferable? and what about air intake hardpipes?
Modified by Bohemiangod at 10:09 PM 4/4/2007
chrismiwilkins
Car: 1990 300zx
I just bought a 1990 300zx nice ride by far it's not tt ether but I want to modified it to be one I found this one site engine trans complete with ecu for just $2000.00 + $350.00 s&h but you need to buy the inter coolers separate but i thought it was a great price. it's called STREET IMPORTS bad a$$ site i think. LATER -C-
