How much coolant comes out?
attofarad
Car: 2001 QX4
When draining the coolant by only opening the radiator (not the block plugs), how much coolant drains out? I'm wondering how much is left in the block/heater core. I am considering using the Zerex Asian coolant, but that is pre-mixed, and I don't want to end up too low percent coolant (will flush with distilled water before adding coolant).
2001 QX4.
-Gary
ezb57e
Not all that much will stay in.
If coolant is changed on schedule, removing the drain plugs usually isn't necessary and a PITA sometimes.
I just mix my own distilled water and a good (factory) coolant, add them together and have a perfect 50/50 mix.
Unless you live where its very cold, any distilled water left in may raise the freezing point a bit but it will be fine.
PS- The big funnels that screw on in place of the rad cap work really well.
attofarad
Car: 2001 QX4
Thanks for the reply. I found another post (think is wasn't a qx4/pathy though, maybe a Murano) where someone drained about 6.5 quarts out the radiator/overflow tank, of about 9.5 total. I'll just do a few distilled water flushes, then add ~5qts of concentrate from Nissan and top off with distilled water.
This was precipitated by a radiator leak I had, between the aluminum fins and the bottom plastic piece. I crimped down the tabs holding them together, and the (small) leak may have gone away, at least for now. With the time I've spend researching (radiators, hoses, coolant, procedures), I sorta wish it would just leak, so I could get done with it!
ezb57e
If the bottom tank (the plastic part) or seam is leaking, even at all, you are postponing the inevitable.
Install a new radiator and refill the system with a 50/50 distilled water/coolant mixture. Keep what's left for topping off.
Don't just fill with the concentrate, and top with water. It will be too rich and heat transfer will actually be reduced.
