how much can the sr hold?
starkos14
Car: s14 R33*, 99 gs300(2jz-gte soon)
i got my motor swap and i was told the turbo can only hold 15 lbs of boost... what about the motor?? i know its somewaht built for the boost... basically, i just dont want to blow the motor and eventually upgrade the turbo what is safe boost levels?
NoStickers
Car: 1991 240sx w/ sr (RIP)
1989 240sx w/ ka
1996 240sx donor car (coming soon)
I didn't even like running 15psi, thats when I started to lean out.
starkos14
well, i realize i would need to tune the car with some fuel upgrades and computer components
spider_slayer
Car: S14 240SX
S13 240SX
if your on the stock fuel pump then DO NOT TURN THE BOOST UP. you won't be able to supply enough fuel to keep the A/F within safe operating range. i also wouldn't if you don't have a fmic. however, if you do have an upgraded fuel pump and fmic then 15 is ok for every now and then.
the block can with stand an incrediable amount of boost with jsut a head gasket upgrade.
starkos14
walbro 255 and i do have a fmic
