Speed-n-Sound »
https://forums.nicoclub.com/speed-n-sound-u3361.html
Sun Jan 05, 2003 5:20 am
To quote Chris Rock -
"Oh you can do it but it doesn't make it a good idea. You can drive your car with your feet too, it doesn't mean it's a good f%$#ing idea."
I have a 1st Gen TSI in the garage right now and trust me lots of guys run high boost, about 14psi, and don't blow motors. Not any higher than 14psi consistantly though.
What they do is blow that notoriously rotten AWD 5spd transmission (2 for me), get engine knock for running lean, and create weak cylinders (those that need new rings.
You see the car runs very hot and causes all sorts of reliability problems after 100k. The engine is unbelievably strong and takes lots of abuse without going boom. But they do self destruct over time. Keep in mind these cars run 10.5psi boost from the factory and can safely handle 14psi usually, sort of like the SR20DET can handle a little more than 7psi.
However, the SR20DET is a stronger motor in terms of crank, and rods. Don't let anyone tell you it's a good idea too run a turbo motor car 4-8psi higher than it was intended to run though. If it could safely do that, they would have obviously risen the boost at the factory. Contrary to popular belief Nissan, Mitsu, Honda, etc. do have some comprehension what they're cars can do consistantly, and maintain reliability.
