how much boost on s15 turbo
DawgMode
Car: 180sx
hoe much boost can i run on stock 370's with s15 turbo
wildacexxx
Car: 2002 Q45 nav sport
no more than 10.
S13240
Every engine is different, only way to know accurately is to hook up a wideband o2 and do a couple runs. Other than that...a good estimate would be what wildacexxx said.
discopotatoe
Car: 1990 240sx..SohC
what about if you upgraded your ecu and 550cc injectors...whats a safe, high boost you can run
pcarp
Car: '93 Coupe
Disco,
I'd recommend using that wideband, like S13240 said. Probably don't want to lean it out...
Where in the 808 do you live? I used to live in Aiea and Pearl City.
You drift at Tantalus? No, wait, don't answer that question...
s13_drftone
Car: S13 with sr20det swap
max boost is 12 dont push it or you well kill you turbo
s13_drftone
12 psi if you car is tune right only
2forty
well an s15 turbo can make power up to 20psi or around there. on stock 370's you wont be able to push much more than 240ish whp. of course there r exceptions but thats more of a standard. its all about the tuning to see how much power you can make.
virus77
Car: 95 S14, 71 240z, 97 e320
s13_drftone wrote:max boost is 12 dont push it or you well kill you turbo
Actually he will kill is engine if he boosts too much on stock injectors, the turbo will be fine up to 18 psi over that it looses efficiency but you can crank it up to 20 if you like.
