ILOVESILVIA(S13) wrote:And why would you want to run w/o an intercooler? Does not sound smart to me. But that's my opinion I guess.
I'd love to reduce the amount of piping between my turbo and intake... less lag, less pressure drop from air-to-air intercoolers, etc...
For the OP:
I haven't run without an intercooler, I can't see you having a problem, enrichen the fuel mixture to keep your combustion temperatures down.
My concern is heat-soak on the charge pipe, you'll have higher intake air temperature however I don't know how to control that except for reducing load (step off the gas) and add more fuel.
If you have an EGT sensor, watch combustion temperature, use that as an indicator as to how much boost you can run. If you put the car under load and you start climbing into the 1900F+ range... get off the throttle...
oh, and run high octane fuel....
RE: the s12 silvia/gazelle, ca18et that had the direct pipe into the intake... I think...
