Search around the forum, man! Your question is too general and will not directly pertain to your particular application. In your other thread, you asked how much boost or what is the max boost or something rally close to this one. If you're curious and want an answer from a member who has the closest mods to yours, email that individual. Most members would saty anywhere from 7-12psi of oost. It all depends on how much you want to run. Like I said, this has been covered before..............burnout 180 wrote:How much boost do you run on your ca18det and with what upgrades and turbo?
Search around the forum, man! Your question is too general and will not directly pertain to your particular application. In your other thread, you asked how much boost or what is the max boost or something rally close to this one. If you're curious and want an answer from a member who has the closest mods to yours, email that individual. Most members would saty anywhere from 7-12psi of oost. It all depends on how much you want to run. Like I said, this has been covered before in the past...........burnout 180 wrote:How much boost do you run on your ca18det and with what upgrades and turbo?
