:: orion :: »
https://forums.nicoclub.com/orion-u7549.html
Wed Jun 15, 2005 8:16 am
ECU doens't care how much boost you run...
...but the timing curve is pretty aggressive.
Assuming you're using some garden variety T3/T4:
4-5psi is perfectly safe with stock ECU, stock base timing. Needs bigger injectors or an FMU.
6-7psi, I'd knock the base timing back 1 degree. FMU is starting to be too crude for fuel control here...injectors and S-AFC are a bare minimum.
8psi needs a couple degrees of base timing knocked off...and that'll almost max the MAF and 370cc injectors.
9psi...you've maxed all the basic + cheap turbo KA stuff (stock MAF, 370cc injectors, and timing is TOO aggressive for long term reliability).
Anything above 10lbs...you MUST get a retuned ECU, standalone, or piggy-backs like a MSD BTM or eManage.
- Brian
