20psi on the stock RB20 turbo? and stock injectors? Give this man a prize. You sir are crazy .NizzansDET wrote:I ran 20 Lbs the other day and hit fuel cut. so i turned it down to 18 Lbs.Does anyone know how much power the stock injectors are good for?
Actually, it's optimum for power, and slightly lean under high boost.NizzansDET wrote:lol 12.8 A/F is rich dude! 14.7 is that prefect air fuel ratio. anything below 14.7 is rich and anything above 14.7 is lean!
Yeah your right what do I know . You should be cool at 20psi on the stock injectors. That should put you at your magic spot of 14.7.NizzansDET wrote:lol 12.8 A/F is rich dude! 14.7 is that prefect air fuel ratio. anything below 14.7 is rich and anything above 14.7 is lean!
NizzansDET wrote:its probably running lean.
NizzansDET wrote:lol yeah what do you know? cant even get a fuel ratio right?!?!
Yup make sure to hurry and get that SAFC so you can put your A/F back to 14.7 at WOT.NizzansDET wrote:lol yeah what do you know? cant even get a fuel ratio right?!?!
You are kidding right?!?!?! Oh wait, you're not are you? Poor, poor engine.Tell ya what. All I ask is that you only tune YOUR engine to 14.7 AFR @18psi on stock injectors.Please don't tell any of your friends how you make all of that mad power. Wouldn't wanna let the secret out.NizzansDET wrote:lol 12.8 A/F is rich dude! 14.7 is that prefect air fuel ratio. anything below 14.7 is rich and anything above 14.7 is lean!
The factory Nissan ECCS system does not have a MAP sensor, just the MAF.NizzansDET wrote:wait. im confused... maf sensor. that reads the air flow. and the MAP sensor read pressure and vacuum. how much boot can the MAP read?
While a 14.7 a/f ratio may be an "ideal" balance, it most certainly will not work long term for even part throttle acceleration. It is just too lean, and lean = heat. It's closer (though not quite) to an ideal "cruising" a/f ratio.NizzansDET wrote:I was just saying the perfect air fuel ratio is 14.7. you make more power running lean. but it will for surly burn up the valves, pistons, and rings. it is better to run rich because the extra fuel cools down the valves and spark plugs. o and what is the stock boost on the RB20?
NizzanDET I must thank you very much. I thought I would never change my Sig quote untill now. Eh? I'm sorry man but his quote beats out the fairy dust.NizzansDET wrote:wait. im confused... maf sensor. that reads the air flow. and the MAP sensor read pressure and vacuum. how much boot can the MAP read?I was just saying the perfect air fuel ratio is 14.7. you make more power running lean. but it will for surly burn up the valves, pistons, and rings. it is better to run rich because the extra fuel cools down the valves and spark plugs. o and what is the stock boost on the RB20?
promise me somethingNizzansDET wrote:lol 12.8 A/F is rich dude! 14.7 is that prefect air fuel ratio. anything below 14.7 is rich and anything above 14.7 is lean!
