I just absolutely hate the PowerFC handheld. Once again you can transfer ignition maps fairly easy to a pfc, not your fuel maps though. Enthalpy since it uses some volt readings from the stock O2 sensor makes its own adjustments based off of that, mafs readings, tps readings, etc... A PFC, or any standalone is linear fuel mapping.
The beauty of the stock ECU, is it takes your reading from your MAFS alot more to heart. With a standalone is doesn't really care, it basically goes for every X amount of air dump 1 part fuel in where X is your tuning curve. A burned ECU like Enthalpys can go away from the curve to make minor driving adjustments, depending on the varying conditions as a daily driver. Make sense?
And I do believe running more than 80% injector cycle is really dangerous, if something fails and you max out those injectors your asking for detonation. Enthalpy and JWT both stick close to 80%.
650cc IMO will be way too little for your setup. Running those injectors at 43.5 psi (fuel pressure, which is what enthalpys tune is set at, unless you had him change it) will have them running at almost full duty cycle at 15 psi. You could blow up your motor.
I would go with something in the 800s even...
http://www.deatschwerks.com/ca...s.php
ps when he says he is your enemy, he means running too lean. If your AFR is too high your running more air, hence alot more heat which could leat to detonation. Running too rich will cause melting. Running it just right, but just slightly more rich than a racing mixture will be perfect for daily driving since your keeping you air down and less heat as well.
pps let me clarify, enriching a mixture keeps the combustion at a lower temperature.
