how much ATF?
vicQ45
Car: 1979 Cadillac Eldog, 1987 Wagovan, 1968 Firebird 400
I was just going to change my transmision fluid for the first time in my Q tomorrow and i need to know how much to use to flush and how much to have in after the flush is complete. my FSM is coming in like a week or two so i will stop asking theses simple questions soon . thanks
DAEDALUS
Car: 1990 Infiniti Q45
Total capacity is around 10 quarts. But you can't get it all out in a single drain. Some report getting only a few quarts out of the pan. I've never gotten less than 5, and usually around 7 quarts. If you can replace 7 quarts at a time and do it twice (with a drive in between to thorougly mix the fluid) you'll get a good majority of the fluid replaced. As always, the dipstick has the final say on whether the car has enough fluid when you're done.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Mechanical flush will require 14 qts.
Manuals and TSB for post 1994 Q45 are available right now at http://www.nissantech-info.com/infiniti/ for a one day subscription.
vicQ45
thanks for teh help! my dealer is out of trans filters and gaskets ATM, so i'm probably going to order them from everythinginfiniti. is there a type of RTV i could use jsut temporarily until i get my gasket/filter in? my fluid seems pretty badly burnt...
DAEDALUS
For short periods of time you could probably get away with the Permatex stuff. Not good long term because the interface isn't designed for RTV so it would leak sooner than the solid gasket would. Consider the extra labor required to clean the RTV off later.
vicQ45
thanks for the help. turns out o'reilly had a filter kit in stock even thought they said they didn't :-D
vicQ45
sorry, another dumb question.. where is the correct level on the dipstick? below the top knotch? i filled it to where it was before, which is like an inch above the top bend/notch. is this too much? should i let a little out?
DAEDALUS
Should be 2 notches with cross-hatching between them if I recall. Keep it at the top notch or just below it. If it's below the lower notch you need to top off. Sounds like you do need to drain some out.
vicQ45
thanks daedalus! ill do that tomorrow when its light out.
vicQ45
do you mean the section with the cross-hatching(HOT/COLD)? or between the 2 bends on the stick
Heres a bad ASCII drawing of the dipsitck:
| || | <--Mine is here| || |( (| |<--Should i fill up to here| | | ||_|COLD|#|<--or here?|#||#||#||#|| |( (| ||_|
