How much am I looking to spend on a running rb25
aznromeox
I just want an estimate what I'm looking to spend on a rb25det into my '90 s13..... Just interested. I'm trying to have it done around winter. I have about $4000 cash and a '87 bmw 325 i got free worth $3000...... so?
-Ron
Joe
my friends and i were estimating this, with everything as long as you do the wiring yourself and dont get screwed when you have the driveshaft made.
it comes out to about 1000-1500$ + cost of engine.
of course this includes mounts, clutch, driveshaft, service manual (r33 and the 240's) fluids and a few hundred bucks for miscelanious stuff
you can do it a lot cheaper if you use the crossmember and take your chances with the clutch that comes with the clip.
JonPowell
Car: Cars, Music, My family
Mine cost :Clip:$2500Shipping:$800Drive shaft:$400Fuelpump:$150The rest was all fine from the clip I got. It had only 30000 Km on it. I used the KA radiator and fan and also the RB fan. Wired them to a switch inside the car. I also used the SOHC Steering lines and just wound the high pressure line up inside the engine compartment below the intake tubes. I dont see any reason that if you are going to do this yourself it should cost much more than that. If you need help let me know.
Jon
cyris3d
what spark plugs u using with ur rb25??
JonPowell
I used the ones that came with it. I figured that it was such a low milage car and I cleaned & regapped them. They seem to work perfect.
cyris3d
any clue on what plugs to use.. part # if ya got it... NGKs.. anyone know
aznromeox
What lines or steering lines would i need for my 1990 240sx.... I know the steering system is a little different, does that need to be changed?
JonPowell
You can use the lines you have, you just need to move the reservoir to the drivers side and have a high pressure line made up. I used the RB reservoir and turned the bracket inside out.
cyris3d
JonPowell wrote:I used the ones that came with it. I figured that it was such a low milage car and I cleaned & regapped them. They seem to work perfect.
eh?
SHIFT_Lock
Car: kouki s14
same plugs as a z32 TT.
mmerritt2
jonpowell- where did you get your clip from and for how much? that is low miles!
mmerritt2
my fault i didn't look close enough..... your price is up there..... sorry!
JonPowell
When you look at what I've got so far, I got a potential 12-13 second car for under 5Grand, Including buying the car!! I dont really think that is up there. My clip included a 3" Blitz cat-back exhaust, all body panels and lights (which I've already sold) in pristine condition, 2 transmissions a driveshaft(R33 RB25 Auto) , Everything you would need to put together either manual or automatic. Even came with a good clutch!
mmerritt2
yeah, but where did you get your clip from?
JonPowell
I got it from a place called RS Imports, they are no longer carrying RB clips, but they do get alot of other motors in all the time. Their email is [email protected]. The guys name is Ryan. Seems to be a good guy to deal with.
mmerritt2
thanks, too bad I only want a RB!?
JonPowell
There is a guy in detroit trying to get rid of his, I will find his email and post it
JonPowell
i'm selling my Rb25det clip .. decided to go with a rb26dett instead.
Here is a pic of the clip its very clean and has a garentee start up warrenty!
Note this is the actual clip that u see forsale!!!
Selling it for 3300 .. what i paid for it.
Email me at [email protected]
mmerritt2
check your email! thanks
JonPowell
That is not my email, it is a guy on automotive forums. Here is the link
http://www.automotiveforums.co...ber=3
I didn't make myself clear, I apologize. I saw this on another forum and am just passing along the info
mmerritt2
oh, sorry, disregard email i sent you!
JonPowell
You may have sent it to the guy selling the clip, not to me....Sorry.
mmerritt2
yeah, i think i did....do you happen to know where he is located? (the guy selling the clip?) thanks...and sorry again!
JonPowell
Detroit I think is what he said in the thread I linked to previously. The clip looks like it is an auto but he says it is manual. I couldn't see the clutch cylinder in the picture though.
mmerritt2
detroit's not bad either...... i hope it is a manual!!! it is a clean looking clip! thanks for your help!
JonPowell
Here is a pic of the clip, the guy says that it is manual but it looks like auto, I cant see the clutch master cylinder in the picture
JonPowell
If you need help installing it, get ahold of me.
mmerritt2
will do! do you know if it is farther to Detroit or Albany?
PROJECTRB240SX
Car: 1972 DATSUN 240Z W/ SR20DET
JON, SLAVE CYLINDER IS CLOSER TO THE ENGINE BETWEEN THE MASTER AND ENGINE. JON ARE YOU WILLING TO PART WITH YOUR RB25 AUTO? I'LL PAY THE SHIPPING IF YOU WANT TO GET RID OF IT.
JonPowell
I have the automatic trans if that is what you are talking about with the torque converter. Email me and I will send it. What are you willing to offer?
