How much AC Oil to add, where to add?
General discussion area for the L33-chassis Altima.
Oak47
Car: Nissan Altimas 2001, 2005, 2013, 2015
2015 Altima. hit a deer and had to replace the Condenser.
How much AC oil should I Add before recharging the AC with refrigerant, and Where do I add the oil? (directly to the compressor?)
Everything else that was damaged on this car is finally finished. Hood, Fenders, Bumper & cover, Splash shields, Head lights, ECM wiring harness, Radiator & support, condenser, wheel Airbag, both Seatbelt pretensioners, SRS Control Module. (Aligning the Hood & Fenders on this car was a nightmare).
Thank you for your time.
Oak47
I figured it out, how do i delete this thread?
No need to delete - How did you figure it out? How did the repairs turn out?
amc49
Car: '11 Nissan Versa
'17 Nissan Altima
It is VERY common to add too much oil, I saw it a thousand times when I was in parts. You need service manual to detail the exact amount if replacing a specific part and if oil was lost during a catastrophic pressure fail you get to start all over.
Even so much as a little bit too much oil can greatly affect a/c cooling as the system is designed to work with a 100% amount of refrigerant and the extra oil takes up space needed by the other to result in lower cooling.
Return to “5th Generation Altima Sedan (2013-2018)”
