xxcrashxx »
https://forums.nicoclub.com/xxcrashxx-u44767.html
Fri Mar 04, 2011 8:17 pm
got a 95 j30 OBD1, pulled 32 and 34 from ecu. i want to try out the KS bypass trick for a tank or two. ran out to radioshack and got a 1M ohm 1/2 watt resistor. according to the pic in the j30 FSM, its the back connector, which on my car has 3 wires. white, black, white. the connector in front of it only has 2 wires. i know that a knock sensor only has 2 contacts on the actual sensor. so does the knock sensor "sub-harness connector" have 2 or 3 wires??
or where precisely is the connector located?? is it the one connector thats at the far back, dead center of the engine, "hiding" behind the bars that go across the back of the engine? or is it one of the two connections that are mounted right above the back right fuel injector??
