jtsarnak »
https://forums.nicoclub.com/jtsarnak-u3215.html
Mon Nov 15, 2004 4:09 am
Several things:
I opened up the throttle plate and took a little look around and nothing out of the ordinary showed up. It was dirty, but not oily wet looking. If it was coming in through the intake, it could be further downstream, but I don't know.
My mechanic indicated that I could still have good compression with a ring problem because the compression ring could be fine and doing its job but the other rings may not be.
My mechanic also said that he looked down the spark plug holes and could see oil residue heavier in the first cylinder (the one with more leakdown) but that there was residue in all cylinders. This doesn't necessarily mean I'm burning in all cylinders. I could be burning in 1 and then recirculating oily exhaust gases into the other cylinders through the EGR system. It could also be build up from when the timing chain was off 2 links and it was smoking like a chimney.
Finally, I have a slightly shaky idle after the car has been run about 20 minutes.
I'm going to get in contact with the machine shop that did the block/head work this week and figure out a plan of recourse, but any further insight would be appreciated.
(or if you want a really nice chassis/body for an SR swap, I'll sell it to ya )
