NISTECH »
https://forums.nicoclub.com/nistech-u7581.html
Tue Jul 26, 2005 5:01 pm
No there is no temp switch as the car has a mechanical fan. The other fan is controled by the ECM it only turns on under excessive heat conditions[ basically overheating] Otherwise that electric fan only comes on with the A/C. You would need to find a temp switch that like closes a the switch at around 180 to 185 degrees, then wire that switch to a relay to ground the relay and close the relay switch having the switch side wired to the fan.
