How many times can a KA24E be clean bored ?
LT_Z
My donor block from the junkyard appears to be a rebuild of some type, my question is how many times can the block be bored before it starts affecting performance, or causing heat problems ? thanx !
WDRacing
If the block doesn't have scratches in the cylinder walls, just change the piston rings and ball hone the cylinders. As far as how far over the block can be bored, I wouldn't think more the 30 over. You'd have to measure it.
WD
huguetpj
Car: 93 KAT Coupe
I believe the FSM says 1mm, that would be about 40 over
95_240sx
Car: My baby (car)
I want a Ka26det :)
Rick
SingleCamSam
Flatlander is going to make a stroker kit for the DE, they already have one if somebody wants to make a KA28ET
