young-gunn wrote:the only thing is the box may be too small for a decent resident cavity.
Please say, "Air Volume"
I don't recall, is this a sealed or ported box? If it's ported then the frequency response will change a bit, but the tuning frequency of the port will stay the same.
If it's a sealed box the frequency response won't be too different if the motor structure is the same(same model line). Note: If the driver can physically and thermally handle it you can extend the low end frequency response of the system, but this requires a LOT of power due to the fact that you're trying to overcome the airspring/compliance of the air in the enclosure.
young-gunn wrote:The only thing is, the amp I have (got it for free) is rated at 1000 watts, would I need to buy a better amp to power these or is it possible to make this amp work fine?
Any amp can power any speakers. Who makes the amp that you have? And what model is it? That way I can look up the stats and reviews.
young-gunn wrote:I like the Clif Designs ones because they look better and have thicker foams on them
What you're refering to is the surround. If it is foam I would not go with that foam. You should look for somethign with a butyl(sp?) rubber surround.
You don't need to look at the actual size of the surround, just look at the Xmax spec from the manufacture. A larger surround does allow for a larger Xmax(is the spider is able to accomadate it, and the VC won't come out of the gap), but it also reduces the actual surface area of the driver, thus reducing the volume of air that the driver moves, thus reducing SPL.
