Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Tue Jun 24, 2008 6:01 am
The physical FACT to always keep in mind is the farther from the engine [distance] the less important a restriction is!
Exhaust restrictions only reduce power because some old burned gases are not fully purged from cylinder limiting the amount of new fresh air inflow. But the exhaust temperature is so high [1500+F] that this heat expansion pressure overcomes a tremendous amount of backpressure.
Always measure back pressure in front of cats and after cats to get an idea and calculate what improvements can do and cost per HP gained.
On average a mechanical change costs $100 per horsepower gained once you have crossed the built in [designed in safety restrictions].
