You're running soooo much boost and the car is netting you 16s in the 1320? Something is wrong. You do realize that the Silvias with CA18s run a better time in factory trim? Something is wrong with your tuning or are you just lighting-up the tires throughout the launch, 60ft, etc? I wouldn't be pushing 25psi or even 20psi in your case until you've sorted out your engine management and even your fuel system because those injectors are not enough for the type of air flow you're chasing after. I run 15psi on all of my cars for street use and the power produced is just wicked and that's mainly because of the tuning, not the hardware. If it's not tuned right, it's not going to run right, so work on that tuning and please lower the boost before you mess-up your precious engine.JNM240 wrote:So after a few trips to the dragstrip and may nights sitting infront of the computer (and laptop) figuring out NISTune, i think i have finally got things working right. Shes boosting GREAT now!
Currently i am pushing 20 PSI with my GT2871R .86 a/r. I have 550cc injectors, a Z32 MAF, and 3" outlet, downpipe and testpipe ( 2 1/2 HKS exhaust however). Engine was built using ACL Calico coated rod and main bearings, Cometic MLS head gasket, and ARP head studs and main studs. AFRs dip down to 10:1 on full boost right now, without ANY knock at all. Wondering, based on this setup, do you think i could get this turbo to 25 PSI safely? Maybe even higher?
I might be trying the track again tomorrow night, all by myself this time, seeing as i still have the slicks on the back. Just wondering if anyone has any warnings about pushing it to 25 pounds of boost. Last time at the track, i couldnt get out of the 16's. Turns out my K value, which i adjusted using the wideband, was still severly out of whack. So the guy i work with who has a 69 Chevelle (350 small block) ran low 14's all night and the smack talk was merciless the next day.
If anyone manages to get 350hp out of 550cc injectors, you are just a hair away from melt-down.mbmbmb23 wrote:What map did you start with as a base map for your tuning? Assuming you are putting out around 350hp your 550's are almost maxed at 43.5 psi base fuel pressure. I'd upgrade to 750's before you cranked it up more.
That's what I was thinking.boost_boy wrote:If anyone manages to get 350hp out of 550cc injectors, you are just a hair away from melt-down.
Dee
What RPM are you launching at? Tire pressure? Ive never drag raced before but I'd be willing to bet that launching more controlled at lower RPMs and not wheel spinning would pick up some time on the slip. Look at how they test production cars for Road and Track magazine or other mags....they're not doing burn outs to heat up slicks....they have factory tires and they get lower times with cars you should be faster than.JNM240 wrote:Yeah, car ran a 14.9 at 100mph the first time ever down a dragstrip. Since then, ive put in NISTune and it hasnt been tuned correctly. Until now. My K value was way out of whack, even tho the car ran GREAT at idle and cruising. Under boost, it fell on its face. That seems to be sorted out now, as it actually PULLS HARD under boost again.
The track is a 1/4 mile track. The chevelle is a POS rust bucket. Another guy has a 3rd gen RX7 with a LS1 and a 150 shot running 10.8 at 136MPH.
Went tonight by myself and had issues every pass. First pass: redlighted. Ran a 17.60 at 101.83 with a 5.63 60ft time (cause i paused once the red light went off). Next 2 passes had all kinds of traction problems. It was about 45 degrees out, and i couldnt get the damn slicks hot enough. Wheel spin off the line and throughout second gear both times. Results: 16.45 at 98.02 and 16.34 at 96.06. The car is absouletely booking it once it gets moving, its just now a problem of the drag race: the launch.
