PsycoGeek »
https://forums.nicoclub.com/psycogeek-u199128.html
Wed Feb 22, 2012 5:19 am
How many miles are on your Versa?
We have a '98 Plymouth Voyager (that has a Mitsubishi V6 motor) and it was ticking on colder days. We had to have two brake lines replaced (they popped, then no brakes!), and while it was in we had them replace the way overdue timing belt replacement service. Should have been changed at 75K, and we went to 96K before the service. Hasn't really ticked like that since (only a slight and almost inaudible tick on the coldest days, probably from waiting too long to change the timing belt).
If your valve train is ticking you may have an issue with the timing chain being stretched, or rocker arms that need adjusting. OR... your engine oil might be really low. Hope you get it sorted out.
Almost forgot to add this... no valve train noise. Shouldn't have any either at @13,650 miles!
