How many of you have had oil problems with your SR?
HurryupandrunS13
Car: 1992 240 fastback
Just curious, but how many of you have gotten an SR with spun bearings or oil pressure problems? I got mine with a spun bearing, and a friend got one swapped, took it out and lost oil pressure within 5 minutes. I also have seen guys that have had no problems at all, more than not. Is this more of an isolated thing, or is it fairly prevalent?
Tulsa_S-13
Car: 1991 SR 240sx
Nope, no oil problem here. That problem would be related to what quality motors your importer got in. It's also a good idea to replace the oil pump before you swap in your SR. I mean come on, these are junk yard motors we're getting, they sit around for who knows how long before they are even picked up.
So next time:1. Buy from a reputable importer2. Replace oil pump 3. Install oil pressure gauge
srdub-t
Car: white 91 SR22 powered coupe 240sx, 95 black c36 amg
my buddy was running around untuned and was running super rich and spun a bearing
Sil80315
Car: 1991 Nissan 240sx
anything with stock oilpan and heavy throttle will do that. I try and stay safe with buying sr's by buying them an automatic and just put a 5spd trans on. Figure no one wants to beat on an automatic stock sr lol
Stripes
Car: hatch, coupe
srdub-t wrote:my buddy was running around untuned and was running super rich and spun a bearing
I don't get what being un-tuned has to do with it unless you've got a bigger fuel setup or built motor.
painengaged
Car: s13 sr20det
nope havent had that happen
Sileighty_85
Car: 1991 180SX
Untuned = too much fuel = cylinder wash = fuel and oil mixed = chemical break down of oil = spun bearings
It gonna more common with Red Tops SR's now seeing that these engines are around 16 year old
I highly recommend always replaceing the oil pump in R/T SR's
I had a friend's SR with a Bad oil pump when we first dropped it in.
Stripes
Car: hatch, coupe
How would you be getting too much fuel if it's a stock setup though?
Sileighty_85
Car: 1991 180SX
Stripes wrote:How would you be getting too much fuel if it's a stock setup though?
well he said he was untuned so that would mean he had bigger injectors and the ECU was not tuned for them so it was running too rich
HurryupandrunS13
I had a bad o ring leak in mine and literally hydrolocked cylinder 4. But washing down cylinder walls will spin bearings for sure.
Stripes
Car: hatch, coupe
HurryupandrunS13 wrote:I had a bad o ring leak in mine and literally hydrolocked cylinder 4. But washing down cylinder walls will spin bearings for sure.
When I had my 550's in before I got my motor running properly I hydro locked my motor several times. Sucks, and changing oil gets expensive after you do it every day for a week.
LeroyBrown
Car: 1995 nissan 240sx s14 blacktop
my car runs good and i still have the original oil pump.
s13-t
Car: s13 pig nose w/blacktop sr20det
About a month and a half after my swap I lost oil pressure. when i first started the engine it held 18psi at idle when warm. Then i noticed it drop every couple drives. wound up getting down to 11 psi at idle. Now the car is sitting, waiting for parts from money I dont have But the moral is that whenever you do a swap you should always replace as much as you possibly can with new oem parts that way you dont get these problems
HurryupandrunS13
s13-t wrote: But the moral is that whenever you do a swap you should always replace as much as you possibly can with new oem parts that way you dont get these problems
Yessir! We should get a how to thread going for oil pumps. Remove old pump, insert new.....
