float_6969 »
https://forums.nicoclub.com/float-6969-u780.html
Fri Nov 18, 2005 12:36 pm
I'm with C-rad on this one. Unless you are beating on it, and then just shut it off, the TT isn't necessary on a water cooled CHRA .
As far as the water not circulating, that's not true at all. If you've hooked the lines up correctly to the back of the intake manifold, the coolant is moved through the CHRA via convection.
To explain, if you look at the coolant lines, you'll notice that one comes up from the bottom and the other exits from the top, heading towards the back of the intake manifold. When you turn off the car, the coolant in the CHRA heats up. The heated coolant rises up inside the coolant line, up towards the manifold. As it moves out of the CHRA, lower temperature coolant moves into the CHRA behind it. This lower temperature coolant draws heat away from the CHRA, which causes it to heat, rising up the tube away from the CHRA towards the manifold. This process repeats until the CHRA is the same temp as the rest of the coolant in the system. Also, at some point, the coolant reaches the back of the manifold. This is important for a couple of reasons. First is that the back of the manifold is the high point in the system and is where all bleeding should be done from. For a convection current to work well, you need it to be able to rise as much as possible. As it reaches the manifold, the exit is a coolant line that runs straight down. The reason for this is that after the motor is shut off, the manifold acts as a heat sink to cool the heated coolant coming from the CHRA so that it can drop back down, feeding the cycle of coolant for the CHRA.
If that's not clear I can draw a picture :biggrin
