M4T5 »
https://forums.nicoclub.com/m4t5-u123303.html
Sat Jan 03, 2009 6:37 pm
Not sure how they are about it. Just keep every receipt you do on the maintenance!! That will be your only defence if they deny a warranty repair due to lack of maintenance. I cant see them telling you that you cannot do your own maintenance if you want to keep your warranty. The only thing I will have them do is the trans fluid change/ refill (No FLUSH!), rear diff fluid change, brake fluid flush, power steering flush (if it is even needed), and coolant flush. I would do the trans fluid drain and refill if I knew it was fairly simple and didn't require the fluid to be extracted from the trans instead of drained.The oil changes, air filter (I'll be changing to K&N when the air filter needs replacement), all in cabin HVAC air filters, brake jobs, and super charger install (Yeah...I wish!)
J
