Wulfgang wrote:Not all butt connections (or other mechanical connections) are cheap. Don't forget that Nissan, most (if not all) other OEMs, the Army, the Navy, your local electrician, etc. all use mechanical connections. Also take a look at arc welders. They have ZERO soldered connections.
The best connection you can make is a mechanical connection using a good butt connector or crimp or whatever. People rave about soldered connections all the time on car forums, but there is no basis for that argument.
There's are a LOT of factors that determine what type of connection is necessary. Soldering is used widely. It's popular, more reliable than a butt connector, and saves space. No one likes to use a bunch of butt connections right next to each other. Solder and shrink tubing is the way to go. Plus, you're not risking smashing wires in the butt connector which could lead to problems later on.
In most cases butt connectors are fine. I personally won't use them. It's not professional IMO. And I've seen them fail too many times... but we all do what we want and when it works we always assume that it's the best way to go.
Researching about this stuff will eventually give you a basis for your desire on what type of connections to use.
