rgk »
https://forums.nicoclub.com/rgk-u245656.html
Fri Oct 09, 2015 12:27 pm
Oh sorry, just a rad flush will be less than 10.95. That amount is for the radiator, engine block, reservoir, everything. 3.8 liters (one gallon) plus 3.8 liters of distilled water (another gallon) will be more than enough for just flushing the radiator.
It's recommended to run fresh water through the radiator to clean it out after dumping the old fluid. Then, after draining all the fresh water, add your coolant mixture.
